It is currently Thu Aug 21, 2025 9:16 pm
 Post subject: Mortise Size
PostPosted: Tue Jul 09, 2013 11:27 am
Last Name: Ensor
City: Springfield
State: Missouri
How wide do most people make their neck mortise?
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Mortise Size
PostPosted: Tue Jul 09, 2013 11:39 am
Yep, 3/4" seems to be standard. Martin M/T necks and three CNC suppliers that I know of use 3/4".
PostPosted: Tue Jul 09, 2013 1:11 pm
I use the 3/4 tenon.
Barrel bolts are no problem. If you can't find the exact size you can grind the ends a little, you might need to hacksaw the screw slot a little deeper if you do that so you can still get the bolt-hole lined up correctly.
Old growth, shmold growth!
PostPosted: Tue Jul 09, 2013 2:18 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
For anyone who is having trouble finding the hardware locally- The Lowe's in my town seems to have a better assortment of fasteners than Home Depot but did not know what a barrel bolt was. After much sifting through the hardware drawers, I found what I was looking for. They were labeled as "cross dowels".
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Jul 09, 2013 2:48 pm
...or just mill the mortise and tenon a little wider to provide clearance. ;)
Sure. If you want to.
PostPosted: Tue Jul 09, 2013 3:20 pm
Yup.
I pretty much lay out every guitar as I go.
You can modify the approach to fit the hardware if you want.
Or you can make the neck tenon how you want it and modify the hardware to fit it instead.
It's a very flexible approach.
PostPosted: Tue Jul 09, 2013 3:58 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Filippo Morelli wrote:
Best part of not having a mortise. :mrgreen:
Filippo
If you don't have a mortise, where do you stick your tenion? beehive
PostPosted: Tue Jul 09, 2013 5:01 pm
Filippo doesn't have a tenon. Or, it's very small. I don't know, I haven't seen it.
